Question How to butterfly click on a small mouse
Nov 17, 2021
53
Hi, I have a mouse called the PC306A from pictek. It has a really small mouse space, so how do I butterfly click at a decent cps?
First:
This mouse?
https://www.aliexpress.com/item/1005002777324613.html
Second:
"Butterfly click".
This ?
https://www.clickspeedtester.com/butterfly-clicking/
As I understand the posted question the solution is practice.
However, if there is some physical constraint or limitation (small mouse space) then a larger "mouse space" is needed.
A different mouse may be necessary....
Are you able to try and test other mice? Is there some driving requirement for using the PC306A mouse?
Yeah, it's about as big as a g502, which is pretty tiny. Seen people do it on smaller mice, but I don't quite know the technique to pull it off.
Likely a matter of practice and muscle memory.
However, there are many variables and there certainly could be some combination of variables that simple make the process cumbersome and awkward for you.
Hand size being one, Finger joints, flexibility, etc.. Ergonomics.
For the most part you may need to do some experimenting to discover what, if anything, does work for you. And what works probably will involve some trade-off's.
I found a number of "Butter-fly click" links via a Google search. Explanations, videos, clicking speed tests, etc..
Not at all sure (full disclosure) how real and effective that all can be.
I am going to move this thread from "Computer Peripherals" to "PC Gaming" with the hope of soliciting further ideas and suggestions from the PC Gaming community and those who are more likely to use Butterfly clicking.
