Hello everyone! I'm building my programming and gaming PC, I only play Dota 2 and LoL but will compile a lot of code. I will run this PC 24/7 so I need a good cooling system (good but not expensive because I'm on a budget). Here is my rigs:
Which specs (airflow in CFM and pressure in mmH2O) of fan should I looking for, to create a sightly positive pressure environment?
Is there a way to calculate CFM (or mmH2O) of a fan which has dust filter attached?
(I will connect fans directly to PSU, let them run 100% rpm all the day)
CPU: Intel Core i7 6700
HSF: Cooler Master Hyper TX3
GPU: MSI GTX 750 Ti OC 2GG
MBO: MSI B150M Mortar
RAM: Kingston HyperX Fury 2x8GB DDR4 2133
SSD: Samsung 850 EVO 250GB
HDD: Western Digital Caviar Blue 1TB 7200RPM
PSU: Antec HCG-520M
CAS: Cooler Master N200 Windowed, included 2 x CM XtraFlo 120mm
And 2 more 120mm fans for this chassis
