How to change a three pin case fan to a usb plug case fan?
goheenis
Hi all, Im making a computer cooler table for my laptop computer and I'm having trouble changing the three pin plug that came with my led case fans to a usable usb plug can anyone help me out? ill try to add a picture of the unit with fans installed.
Please if you can help:) Thanks...
I think USB is only 5vdc, so you can't put a 12V fan on USB. Might have problems with curent ratings if you can make it work.
Google the pinouts of a USB connector and see what the specs are.
Yep, only 5 volts and max current only 100mA. Nope, no workie.
