How to change between DVI and VGA sources on samsung SM2333 monitor
medoampir
19
Hello,
I connected two devices to my Samsung SynchMaster2333 monitor as the following:
DVI: playstation 4 (I used an HDMI to DVI adaptor to make the connection)
VGA: PC (I used an HDMI to VGA adaptor to make the connection)
now the PC is showing on the monitor (VGA), how can I switch to my playstation 4 (DVI)
I did it once but I don't know how and can't do it again.
Some monitors have an autodetect function that selects the cable that is actively connected to a source.
Others have a switch, either physical or on screen where you select the input source.
If it is autodetect, turn off the pc and turn on the playstation.
If you have both pc and ps4 powered on, the connection will likely go to the first connection it finds.
