how to change front fans in rosewill blackhawk case?
Apologize for not getting this up yesterday as promised, im not only my family's go to person for computers/home theater/networking issues, but also for cars.
Anyways, fans come out just as said above. Pull off front cover, unscrew fan(s) from front, slide out the side. Of course make sure when you put replacement fans in they are oriented correctly as an intake (arrow pointing towards inside of case).
http://youtu.be/A3jgL8TUUdo
on page 6 it shows how to remove the front fans from the rosewill blackhawk case.....
no it doesn't i didn't see anything on page six about the front fans i saw the two top fans but not the two front fans
i just checked and it won't let me... i'm thinking now when the fans die just buy a new case because i can't figure it out and i don't see what else i can do
I pulled out the fans on my case to snip the annoying LED lights on it, a few months ago. I believe you have to pull off the front cover, just pull from bottom, and then you unscrew the fans from the front and then you will have to slide them out the side.
If you dont get your answer in the next 6-7 hours I will check it when I get home from work as I have the blackhawk case.
ok thank you very much :) if it's not too much to ask do you think you can post a youtube video with a link on how to do it?
thank you for helping me
