So first of all, I am a newbie. Please be as specific as you can because I dont realy speak tech.
I have an NZXT Phantom 410, and it has 3 fan levels.
I only use the first and the last one(for gaming), so I thought of changing the lowest one to a silent mode, and the middle to the lowest.
1 - How do I do that?
2 - Is temparing with the bios for changing fans makes the warrenty void?
3 - What speed do you recommend for a silent mode? (Now I have the default ones)
Thanks in advance,
Amit
Thanks in advance,
Amit
