How to change nvidia fan speed?
billy1986
25
Got my computer back from repair today. The repair guy changed my graphics card from a hd-6450, to a Geforce 8400 GS because he said the 6450 wouldn't post (it seemed ok before I gave it him)
My problem is, I need to know how to change the gpu fanspeed.
I've updated the drivers and got the Nvidia control panel, and I've also downloaded MSI afterburner.
But i still can't work out how to change the gpu fan speed.
On my old 6450, i changed it on catalyst control centre....
Ok. I see where it says auto. but when I click it nothing happens,
When you un-select Auto, A slider does not become movable?
1. remove the light from AUTO by clicking it once
2. Adjust the fan speed
3. Apply
Let me know if this helps
No. I am unable to select the box with my cursor. And there is no light.
EDIT
The above user would almost certainly be correct then. The cards fan is not designed to be controlled. Past of the cost cutting for lower end cards.
FIRST POST.
You bring up an interesting point. I almost forgot about the lack of speed control on some lower end cards.
All my low end cards are passive : )
Does the card even show a speed in afterburner?
Technically 2 pin fans can be controlled with voltage, but maybe they never did that for video cards.
Good catch coozie7
No. The afterburner does not show the fan speed. I am not planning on keeping this card for too much longer. I just need it for a few weeks until I'm debt-free. Then an upgrade will be coming.
The msiafterburner states that the GPU is running at 59`c. whilst converting black ops on steam.
I don't really recall these temps with my 6450. I recall idle at around 30 - 35`c.
However, The fans on the 6450 were set to 100%
All cards run at different temperatures.
The 6450 is actually much newer(and in this case faster). It is based on a smaller manufacturing process making it run cooler as well.
As long as the fan is spinning and the cooler is not glogged with dust. The card should be fine.
