Question how to change prebuilt pc cabinet?
Nov 14, 2020
I got a prebuilt pc (Lenovo 510s desktop) i wanna know how i can change its cabinet pls tell cause i need to do it cause i need more space in it
idk if we can change prebuilt pc cabinet so i wanna know.
From looking at the motherboard, it's a custom shape that won't fit in a standard computer case, there are also several models of a 510s and they have different motherboards. They have custom power supply connections and possibly custom case connectors. Best thing you can do is buy a standard motherboard, power supply and case then move the CPU/RAM/Drive to the new motherboard and do a clean Windows setup on that build.
If you need to slap in a better CPU cooler and/or power supply, then you can just get a regular h310m or b365m motherboard and a regular ATX case.
