The case had blue led fans so I took 'em out and put some green led fans. Now, the only thing left is the power button, but I don't know how to change the potwer buton led.
Since the start button is an intergral part of the case you will have to look behind that start button area to see if you can see if an led is plugged into it. If there is a spot that you can see a wire going into a hole and what looks like a small bulb attached then it may be removable.
When you go to this link click on the picture of the green led and scroll to the next picture using the arrows at the top of the window. The next image will give you an idea of what your looking for behind the start button.
So i have the same problem but if i go to the second site of the gallary i only see the led connected to a blue wire....
So i screwd the powerbutton open and there is obly a white sensor with a small red led in it.
