Question How to check Dell 34GKR battery?
hw_user
117
I threw away the battery of my Dell E7440 because it bulged 3 weeks ago. I have been running the laptop without a battery. I finally got a new 34GKR battery today. I plugged the battery in. But the E7440 cannot detect it. The command prompt says no battery is detected and the BIOS says no battery installed. How can I tell if the new battery is bad or my laptop is bad?
Did you leave it plugged in a while so it could charge? Many times they come depleted because they've been sitting on a warehouse shelf forever.
If it's been plugged in longer than an hour then it should be able to be detected at least. What brand is the battery? Where did you order it from? Was it new or used?
Do you own or have access to a volt or multimeter?
Reactions: stonecarver
Link to what you bought?
I ordered the battery from eBay. It is not a Dell battery. I found out later from reading some Google search results saying that Dell may not detect non-Dell batteries. But it is too late. The tiny battery LED at the top comes on briefly and turns off when I plug in the power adapter. I am not sure if the LED turns off because the battery is fully charged or the battery is not detected.
Yes, I have a multi-meter. I need some help measuring the voltage of the battery before plugging into the laptop and after it is plugged into the laptop.
Unfortunately I don't know exactly how to test your specific laptop battery but you should be able to find a tutorial on testing your specific battery type on Youtube or elsewhere. Honestly though, I'm going to tell you that I haven't had much success with any of the cheap Chinese knockoff replacement laptop batteries on any of the Dell or HP laptops. I haven't had to buy OEM batteries, but something decent like Anker.
