How to check revision model without opening retail packaging????
coffeecoffee
331
Hey guys, I was wondering if it's possible to check a Gigabyte motherboard revision model without opening the retail packaging. It's not a big deal but I can't help myself since I'm on a budget; I'm trying to get the best for my money.
Apparently, there are two versions of the Gigabte GA-890GPA-UD3H 1.0 and 2.0.
I called the store and they said there are ONLY two ways of checking.
1) Checking the print on the actual motherboard
2) Checking during system boot up.
are there possible alternatives for checking??? >_<
Coffee
PS: I'm planning to buy the motherboard from This Website
That is possibly the rudest comment I've ever read; not only did you not understand the original poster's question. You also ASKED for "Best Answer"? This is appalling. Tom's hardware is about helping people in need, not because you want "Best Answer". This is just sad.....
You could call the store and see if they'll check the revision for you. I don't know if a website would be able to do that or not. They shouldn't have a problem as long as they don't have to open the anti-static bag. The revision number is printed on the lower left corner as it would sit in a computer case. It should be right next to the lower left mounting hole in the board. It will either say REV:1.0 or REV:2.0.
Hello,
I ordered the GA-Z77MX-D3H motherboard rev. 1.1 at www.zercom.eu. I went to the store to pick up my order. On the label on the motherboard case the revision is printed. It was revision 1.0. So I asked what the difference is. They told me the only difference is the BIOS version, and offered to flash the motherboard to the revision 1.1. I accepted the offer but I have I am not sure if this is the only difference.
I compared the specifications on the Gigabyte website. The only difference I found was:
Rev. 1.1: Whether PCI Express 3.0 is supported depends on CPU and graphics card compatibility.
Rev. 1.0: The PCI Express x16 slo support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
Kind Regards,
Jacques
If you stand the motherboard horizontally so that its name is upright then the version or Rev XX is found on the top left corner (at least for some Gigabyte motherboards of course).
