[SOLVED] How to choose a dual monitor stand
Jan 17, 2019
I had a dual monitor setup for a while now and I am getting tired of them just almost being aligned but never truly aligned,
I've decided to buy a dual monitor stand because of that, but I don't know how to even approach this.
what do I need to check and how do I approach this upgrade?
Both monitors are Dell U2414H
Your monitors have a 100 x 100 vesa mount so that will be the first requirement.
The next is weight; your monitors are 8Lbs without stand.
Is this a desk mount, or can you use a wall mount?
I like wall mount to free up desk space.
To see what your options, go to the Ergotron web site.
https://www.ergotron.com/en-us/
There are all of the technical details you would need.
Be advised that Ergotron is very top quality and will be appropriately priced.
I use a pair of these MX wall mount units with all sorts of adjustments.
https://www.ergotron.com/en-us/products/product-details/45-228#/
