how to choose a graphics card brand if I'll be doing custom water cooling?
BooshMan
So I'm in the process of building my second rig to replace my current one. I want to do a custom water cooling loop on the whole set up which has me caught up on which graphics card to buy. I want a gtx 970 but not sure if I should buy a more expensive one with upgraded performance and overclockin or the reference design. Given I'll be putting a water block on the gpu anyways the upgraded cooling on some of the more pricier cards won't matter but some also have upgraded components and controllers.
Ibreakthings
572
38
Why do you need a custom water loop sounds too complicated it would be better just to get a NZXT Phantom and do some intense air cooling plus with the phantom you can put a 120mm fan INSIDE the case
Similar threads
