how to clean dried thermal paste
abhayv
25
Plz tell me how to remove thermal rather than alcohol.
And even tell me how to apply new coat of thermal
I don't recommend using anything but isopropyl alcohol for removing old thermal paste from a CPU. 99% pure is best and safest, 91% will do if you allow it to *completely* dry.
There are tutorials all over the place on how to apply thermal paste to a CPU. google one up.
Use a razor blade to scrape off as much as you can and do so carefully. As for cleaning off the leftover residue, alcohol works. I've used a q-tip and some degreasing cleaner before and it worked fine as well. Just be methodical about it and work carefully.
Lessthannil
468
Scrape off the dried and hardened thermal paste with a razor edge or something similar. Get rid of the embedded stuff with isopropyl. The more concentrated the better, but if you only have say 50% then just clean it more and then let the water evaporate after wiping it clean.
