how to combine my split ssd drive
halafaour
8
hii guys..
i have a pc with ssd drive 240gb and a 2TB seagate
my problem is that the ssd is split into 2 partition and seagate is a 1 partition. so the C/ now is full causing all kind of troubles and errors in my programs how can i join them so the ssd would only be for the C/ without formatting my F/ "the seagate drive"???
At first, you have to move all important data from the drive. Then you can format the driver and extend your c drive space. I think that your error problem will remove from your PC.
Latest posts
