How to compare performance speed between two external drives?
bernatbosch
Hi guys,
I was checking some external drives and their prices on the website of amazon. I was surprised to see that two models with the same storage capacity (2 TB) and with data transfer speeds of 5.120 MB/s and 625 MB/s respectively (so big difference...) could have almost the same price!
Do you think this is possible? How can two HHD have so different data transfer speed???
model: Transcend StoreJet 25M3 TS2TSJ25M3
data transfer speed: 5.120 MB/s
storage capacity: 2.000 GB
price: 100
model: LaCie Porsche Design - External Hard Drive for Mac & PC 2 TB (USB 3.1 Type-C, 2.5')
data transfer speed: 625 MB/s
price: 109
model: LaCie Rugged - External Hard Drive for Mac y PC 2 TB (Thunderbolt + USB 3.0, 2.5' )
data transfer speed: 130 MB/s although in other spec info says 5.120 MB/s (?)
price: 483
model: Glyph 2TB atomraid SSD USBC (3.1gen2) USB3/tbolt3 (BLK) AR2000
data transfer speed: 6Gbps
price: 845
Another question is how to correctly compare the performance of two external drive models?
Is everything about the data transfer speed? Is it even the most important factor?
Finally, how to compare speeds expressed in Gbps and MB/s?
In addition, you're comparing different types of drives.
SSD vs spinning platter.
The LaCie drives and Transcend are a regular 5400RPM HDD in a fancy case.
The other one is an SSD.
The difference in ?numbers" you see are simply what they choose to tell you.
For isntance, for the LaCie Porsche:
"Delivers speeds of up to 5 Gb/s"
"5Gb/s (maximum theoretical bus speed)" https://www.lacie.com/personal/porsche-design/porsche-design-mobile-drive/#specs
That's like saying if you drive a Prius on a road with a 200mph speed limit, your Prius has a "maximum theoretical speed of 200mph"
Again, the interface is the limiting factor here.
Comparisons? A simple google away:
https://www.pcmag.com/article2/0,2817,2400958,00.asp...
http://www.techradar.com/news/best-external-desktop-and-portable-hard-disk-drives
https://www.cnet.com/topics/storage/best-hard-drives-and-storage/portable-drives/
https://thewirecutter.com/reviews/best-portable-hard-drive/
