Hi,
I've been trying and trying but I'm way confused after reading and applying commands and more commands.
Can someone please help me to finish to configure my router wireless card?
The full configuration is here http://snipt.org/BnZ9
The router is connected to a switch and I can go out.
It uses VLAN 109
As for the wireless I want it to use VLAN 10 and to be secured with WPA and let's say use dhcp pool 192.168.1.0 255.255.255.0
Thank you very much
It uses VLAN 109
Thank you very much
