How to connect 2 4g LTE routers with tplink load balancer to TP-Link router
Apr 22, 2018
I'm stumped.. I have two 4g LTE routers that I'm trying to connect to tplink load balancer TL-R47OT+ and from that run through a tplink desktop switch to tplink wireless router tl-wr841n (I also have a wr1043nd if needed with open wrt installed on it), but all my attempts have failed.. Of any advice or setup instructions or even just point in right direction would be awesome... Thanks
Maybe more what is your question. You of course want to start simple plug a pc into the load balancer and plug only a single LTE router into the wan connection. Then slowly add things.
The really hard part is going to be setting the rules in the load balancer to attempt to use both connections. The way that tends to always work with no problem is a primary and a backup. It is not really possible to use 2 connections to increase the bandwidth for a single session because the IP are different on the 2 LTE connections.
