How to connect 2or 3 fans to 1fan controller, help ;-)
Blufkip
28
Hello guys,
I'm really new to all this and I hope somebody can help me by giving some advice.
I'm about to buy some fans from corsair (air series AF120). And i would like to connect 2 or maybe 3 fans to 1single fan controller.
My question: can i just connect let's say 3 fans by using a splitter to 1 controller. And must those fans be normal or PWM. And 3 pins or 4 pins?
Maybe some 1 can tell me which splitter and which fans i need to make it work.
Thanks in advance!;-)
Blufkip
28
I am going to use an external (bay)fan controller.
And the motherboard is msi z87 mpower. ;)
Blufkip
28
Great you want to help but you havn't answered one of my questions :p
What splitter do i need? Can i connect a normal or pwm or both kind of fans?
Is it even possible to add 3 fans to 1splitter to 1 controller?
Blufkip
28
But if i have a controller with 3 control wheels. Each wheel with 1 molex. And i have got 6 fans. I want to connect 2fans on 1molex (=1wheel). I need a splitter!:p
But ok.
If i do. It has to be a 3pin i guess. And a pwm is only used to control the fan by motherboard.
Got it. ;-)
Btw. The molex has enough power to run 3fans?
