L LuftWaffles Reputable Oct 26, 2015 57 0 4,630 Oct 29, 2015 #1 My motherboard doesn't have any 3 pin connecter (that I see, z87k) how can I connect the fans to my psu? Or are there any other ways?
Solution ThatVietGuy Oct 29, 2015 You need fan splitters, such as http://www.newegg.com/Product/Product.aspx?Item=N82E16812162026 Or plug the fans directly to the PSU Or buy a fan controller, such as http://www.amazon.com/NZXT-Sentry-Performance-Controller-Black/dp/B001E0JH5E
ThatVietGuy Titan Nov 6, 2007 11,726 319 70,240 Oct 29, 2015 #2 You can plug your 3-pin fans into the 4-pin headers on the motherboard. Upvote 1 Downvote
Nuwan Fernando Distinguished Jul 26, 2013 1,133 15 19,965 Oct 29, 2015 #3 Connect the 3pin connector to a 4pin socket on the Motherboard. Align for the left 3 pins when connecting and that should do it. Upvote 0 Downvote
L LuftWaffles Reputable Oct 26, 2015 57 0 4,630 Oct 29, 2015 #4 If I am connectIng 6 fans (3 that come with the case) how would I add the other ones that don't have any left over pins for? Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,726 319 70,240 Oct 29, 2015 Solution #5 You need fan splitters, such as http://www.newegg.com/Product/Product.aspx?Item=N82E16812162026 Or plug the fans directly to the PSU Or buy a fan controller, such as http://www.amazon.com/NZXT-Sentry-Performance-Controller-Black/dp/B001E0JH5E Upvote 0 Downvote Solution
