I am trying to set up a corsair h115i cooler with 4 fans in push pull. The fans are corsair sp140 LED series, the cooler comes stock with 2 140mm fans which I am replacing and the manual says that the pump connects to the cpu header and the 2 fans then connect to two fan cables coming from the pump. The pump also connects to sata power and usb to control it. I just wanted to check that I can put splitters on the pump to fan wires so that I could have 4 fans instead of 2 and wont end up overloading the motherboard header. The motherboard is an asus Z170 deluxe and does have a cpu and cpu opt header that can handle 1A (12W). It also has a water pump header but I assume this is for a custom loop pump. Was just abit worried about having 4 fans and a water cooler connected via 1 header. The fans are Corsair sp140 LED 3pin and the box says they use 0.17A but I presume the sata power connected to the corsair H115i will help the header
