[SOLVED] How to connect 9 argb to a single argb header
anonymous890
219
4
4,695
I have 9 ARGB fans
And 1 ARGB AIO
The problem is my motherboard ASUS ROG STRIX B450-E only has 1 ARGB header.
How do I connect everything so that I can sync everything with aura sync?
I have 3 pcs 1 to 4 ARGB splitter.
Can I use the 1 to 4 splitter, then connect 1 to 4 splitter again on the splitter itself?
Or is there an available hub that can connect 10 argb where I can still control it through aura sync?
Please help. Thank you.
https://www.lazada.com.ph/asus-aura...ck-rgb-led-w-case-i956314321-s3146756390.html
I found this one here.
But the question is. Can I trust this product?
Can I trust any splitter out there? Im afraid it might damage my motherboard/aio/fans.
The branding is a bit cheeky but it looks OK.
Has a few decent reviews on newegg
https://www.newegg.com/black-en-labs-1ft-rgb-splitter/p/1W7-005X-00074
Its a 12v powered splitter, there's not really much to it and there aren't that many about above 6 port.
It looks OK to me personally.
https://shopee.ph/✻-Powernew✻-1-to-...GB-Fan-Extension-Cable-i.110505223.2894735250
I found this one but this worries me, it does not have any connection for an external power.... but I look at the reviews, they seem to be working. If there is no external power to this, what worst could happen? how is that the reviews tell they had it working. I mean connecting 10 argb without external power is a bit ..... meehh. Or is it ok? Should I go with this?
https://shopee.ph/✻-Powernew✻-1-to-10-RGB-Synchronization-HUB-Splitter-for-Motherboard-RGB-Fan-Extension-Cable-i.110505223.2894735250
It shows 2 models, 1 12v rgb and one 5v argb with no way to choose which one you buy.
In the reviews a lot of customers recieved the wrong one.
Also non powered with 10 fans??
I would not chance it, there's every chance of burning the argb header out on the board.
I can actually choose from 5v or 12v so it isnt a problem
"Also non powered with 10 fans??" this one does not really connect the fans itself right? just the argb part.
Even if its just the argb part, theres still a chance of burning it?
This is really a problem, I can only see 1 to 5 splitter from coolermaster so i guess theres no choice but to buy a board with 2 argb header. I dont really mind, the problem is the stocks, its so hard to find rog strix x570 here. I just wanna go with AURA thats why.
