How to connect a 4 pin molex fan to 4 pin motherboard header?
ultra23
8
How do I connect a 4 pin molex fan to a 4 pin motherboard header. I have 4 fans with 4 pin molex ends and a motherboard with (4) 4 pin headers. What would I use to connect each of these fans to the motherboard? Are there adapters? What are my options?
EXAMPLE PWM FAN (it's 92mm. You likely want 120mm. Again, just an example):
http://us.ncix.com/products/?sku=77369&vpn=NF-A9x14%20PWM&manufacture=Noctua&promoid=1071
More information:
Fan control checklist:
*There are two types of fans that have speed control. MOLEX is usually not controllable, though there are some rare exceptions which work with 3-pin/4-pin adapters. The two types are:
1) VOLTAGE (3-pin), and
2) PWM (4-pin)
Additionally the FAN controller must be capable of controlling this. My motherboard supports both PWM and Voltage for the case fans, but only PWM for the CPU_FAN controller. Older motherboards may have VOLTAGE only for everything.
1) Determine what TYPE of controller you have (not always obvious. May have to...
You can hook the fans up with either the molex connection or the connection to the motherboard. They are there to give people the option in case their motherboard does not have the connections. If you go with the molex connections you will not be able to control the fan speeds from within the system.
I do not know if you can go from a 4 pin molex to 4 pin motherboard connection because the molex is strictly power where as the 4 pin motherboard is power plus connections for monitoring and control which molex lacks. Thats why you need a separate controller because it controls fan speed by fluctuating the power to the molex connection.
If the molex is just strictly power wouldn't it have just 2 wires (a pos and a ground wire) instead of 4 wires?
More information:
2) PWM (4-pin)
1) Determine what TYPE of controller you have (not always obvious. May have to just try a fan).
2) Enable fan control in the BIOS if needed.
3) Download and install your motherboard fan control software (motherboard support site).
4) Play with the fan profile. Set to 100%, then 40% to see if the speed changes.
5) Example fan profile: case fan at 40% speed until 40degC then RAMP up to 100% speed at 80degC (it will never reach 100%).
If you don't own a fan you can find some fairly cheaply but you need to find out what controller you have. When you buy the fan make sure you can control the speed:
*Let's say you want to buy a PWM fan. It should show a RANGE, not one speed.
Thank you photonboy. I will try this. I have a 990fx Sabertooth Motherboard. All are (6)4 pin headers for the fans except one and it is a 3 pin header.
These are actually the fans that I have
http://apevia.com/ProductsInfo.asp?KEY=CF12SL-UGN
It is strange it shows one speed but a voltage range.
