How to connect a laptop to a desktop with an ethernet cable
yudhveer
I have a wifi in my apartment but I dont have a LAN coming to my room so I can't access internet on my desktop! Now what I want to do is I want to connect my laptop to my desktop using the ethernet cable without a router, so that I can access internet on my desktop as well as my laptop... note-both laptop and PC run on windows XP! The laptop belongs to COMPAQ and the desktop to IBM!
If you have Wifi connection on your laptop you can do it like this, because it's free:
- connect your desktop and laptop with a lan cable.
- start up your laptop and desktop
- go to connection settings on your laptop, then to adapter settings.
- select wifi adapter + lan adapter and click on the right mouse button.
- click on bridge connections
This should work, the only drawback is that you have to turn on both computers and that the internet is a bit slower.
Well I want to connect it with a ethernet cable only... Well anyway thanks... How much would the USB wireless card cost, can you pls tell me INR (Indian Rupees)/// thanks!
