how to connect a monitor with DVI-D Single link with a graphic card that has DVI-D Dual link
Kemo2014
I have a Samsung monitor which has dvi-d single link port . How can I connect it with a graphic card that has dvi-i dual link port?
Please help
Get yourself a DVI-D Single Link cable, you can plug that into the DVI-I Dual Link connector. You can mix and match DVI connections just fine as long as you can physically plug the cable into both ends.
But I found that the monitor has (VGA / Dvi-D single link ) ports only
and the graphics card has ( VGA / HDMI / Dvi-i dual link ) ports
So , what's the best way to cennect them ??????
here's my Monitor details
http://www.samsung.com/au/consumer/pc-peripherals/monitor/everyday/LS22C300BSV/XY-spec
And Graphics card details
http://www.sapphiretech.com/presentation/product/product_index.aspx?pid=316&lid=1
I appreciate your help :)
