How should I connect a network printer and a PC on the same Ethernet cable? Should I use a switch or a hub? Though the printer is used frequently, the jobs are 1-4 pages in length. When the printer is downloading data, will it interfere with the PC's access to the internet? Can I reserve a certain bandwidth for the PC?
If none of this will work, is there a device that will access the Wi-Fi while allowing the printer to think it's connected to an Ethernet cable? It's not a wireless printer. It's a commercial grade All in One, the Kyocera M3655idn.
Thanks,
Thanks,
