How to connect all the addressable RGB parts in PC to Asus motherboard?
iPaperKillz
182
Addressable RGB Parts:
Asus STRIX Z370-E Motherboard
Cooler Master MasterAir MA410M Cooler
4x Cooler Master MF120R ARGB Fans
2x Cooler Master MF140R ARGB Fans
Phanteks Digital RGB Starter Kit
Phanteks Enthoo Evolv X Case
I am looking to connect all the addressable RGB parts in my upcoming build to the Asus motherboard so that I can control them all with Asus Aura Sync.
The motherboard has only one 3-pin ARGB header. How do I connect the cooler, 6 fans, LED strips and case lighting all to that header?
There are 2 Cooler Master ARGB LED Small Controllers (one is included with cooler and the other with the 3-pack of MF120R fans) and 1 Phanteks Digital Controller Hub (included with digital RGB starter kit), but I have no issues with buying any additional splitters/cables/etc.
Cooler Master ARGB LED Small Controller:http://www.coolermaster.com/cooling/cooling-rgb-accessories/argb-led-small-controller/
Phanteks Digital Controller Hub: http://www.phanteks.com/PH-CTHUB_DRGB.html
I will use one of the Cooler Master ARGB LED Small controllers to connect the CPU cooler's temperature sensor. If I stick to one controller, I will stick to the Phanteks Digital Controller HUB because it has 3 3-pin ARGB headers. If so, is it possible to connect 3 splitters to the Phanteks Digital Controller Hub? Will the numerous LEDs draw too much power and fail to work?
