How to connect android box to lcd monitor and music system
Jun 11, 2018
12
I have purchased a android box Cubetek CB4KTX2 (https://www.amazon.com/VGA-VGA-Standard-15-Pin-Male-Cable/dp/B0002AHT0M)
. i want to connect it to lcd monitor which has port like this(https://www.amazon.com/VGA-VGA-Standard-15-Pin-Male-Cable/dp/B0002AHT0M) and music system which has aux cable like this (https://www.amazon.in/Stereo-Cables-Theaters-players-Speakers/dp/B0753VLL77/ref=sr_1_8?s=electronics&ie=UTF8&qid=1528706640&sr=1-8&keywords=aux+cable+for+speakers) . please suggest.
Thanks for your immediate replie. i will definitely try this. please suggest on connecting music system also as i need to connect it also for sound. my music system use following port for connection (https://www.amazon.in/Stereo-Cables-Theaters-players-Speakers/dp/B0753VLL77/ref=sr_1_8?s=electronics&ie=UTF8&qid=1528706640&sr=1-8&keywords=aux+cable+for+speakers)
Hi, There is SPDIF port in android box. cant it be used as audio output. please suggest
ya i got that. i am planning to buy sony home theator system (https://www.amazon.in/dp/B00NTZL8CM/ref=psdc_1389387031_t1_B073RLK59B) . is it possible to connect my home theator to android box spdif port. do i still need converter or not. please suggest.
one more thing i found while googling is that . if i use RCA female to 3.5 mm female cable it can be used to connect speaker to android box AV port. here are link : https://www.youtube.com/watch?v=0p1hdRfH9XM
What you think on this please suggest.
MERGED QUESTION
Question from testarcs1 : "connect android box to lcd monitor"
