Question How to connect ARGB fans to a motherboard without ARGB header?
Oct 27, 2022
So I have a ID Cooling DF 12025 and Zoomflow 240X which are both ARGB fans and I have a Gigabyte X570 Aorus Ultra Gaming, which I think have no ARGB header. I recently bought Deepcool gamerstorm 5V to 12V fan hub and tried connecting 5 fans to it but 1 fan seems to malfunction, so I tried removing that 1 fan and it all works out, is it because the fan hub has a limit of only 4 fans? I bought argb fans in the hopes that I could control them using my motherboard software but I'm kinda disappointed I wasn't able to do so.
Questions:
  1. What should I do to make these ARGB fans work with my current motherboard?
  2. Is there a better way or any information that I should know to fix this issue?
Oct 27, 2022
Had to quickly check my own PC since i have the same MOBO but 1 SKU down (Aorus Elite) but my board does have an ARGB header adjacent to the primary RGB header. Your board does as well, 2 in fact. Cheers!
Do you mind if I ask for a photo on where the ARGB is located in the board? I can't seem to find it on my board or can't identify which is which
