Question How to connect Case Fan hub molex to PSU?
Aug 19, 2022
6
Hi! I'm building a PC and I'm having trouble figuring out how to connect my fanhub (Darkflash DR12 Pro) to the PSU (Corsair CV650 non modular). The fan manual is pretty barebones about this.
The fan hub has a male molex (or female, not really sure which one is which) and my PSU also only has the same kind of molex cable so they don't fit together. Do I need some kind of adapter for this or am I missing something? Would really appreciate the help! Thanks!
First photo - Fanhub molex
2nd photo - PSU molex
View: https://imgur.com/a/18I42vJ
The connector looks like this from the other side (side you're not showing).
You connect molex from PSU there.
ah <Mod Edit> you're right. apologies for being a dumbass. I just checked and it's there lmao. How did I not notice this??? Thanks so much! Guess I really shouldn't be building a PC this late into the night (1:30am here atm). Anyway you're a life saver!
