How to connect cooler master 650W to asus P8Z68-V pro mobo
shubham_66
68
plz help with dis one...
I connected the 20+4pin into the 24pin of the mobo.
I have a 8pin connector avialable on my mobo,.. and a 4+4 connector and also a 6+2 connector on my PSU.
1.Should i connect something into the 8pin on my mobo or what i have done is ryt????
2.which pin should i connect to my radeon hd 6870 gpu??
That graphic card will use 6pins of the two 6+2 connectors.
20+4 connector into the MB 24pin connector.
And 4+4 connector in the CPU Aux power in the first photo.
In your motherboard - use the 4+4 connector
In your video card use the 6+2 connector.
Thnx a lot for d help...
should i put only the 20pin into the 24pin of my mobo,, or should i put 20+4 pin and also the 4+4 connector??
my graphic card has 2 connectors of 4pin each, so i cant use the 6+2 connector with it. what do i do??
