Question How to connect cooling?
Sep 15, 2019
81
Hi everyone,
So I have connected my fans from the radiator to the fan splitter and then to the CPU_Fan connector.
Should I connect my pump to AIO_pump or to the CPU_OPT connector?
Thanks
Sep 15, 2019
81
Hi everyone,
So I have connected my fans from the radiator to the fan splitter and then to the CPU_Fan connector. Should I connect my pump to AIO_pump or to the CPU_OPT connector?
Thanks
Hi everyone,
Thanks
Depends on the cooler but most require pump to be connected to non-adjustable source so it can run full speed. Most obvious place would be AIO_Pump header if your MB has one. If not, any case fan header but set it to full speed in BIOS.
