How to connect DSL Internet to Wifi without cable
Golden Lion
9
Dear all,
I need help to connect wifi by DSL internet. My company keep two modem up down one is DSL internet and another one is Cisco 871 in my cabin. which is connected to DSL by LAN cable in put Cisco WAN port.
The main problem is I can't touch the company desktop computer or download any software for wifi.
I search about this all saying can do this this but I can't touch company computer.
I just put the LAN cable in DSL internet modem and my Laptop for internet but I also don't want to put the cable.
My question is
-: which wireless router is the best without cable to connect the DSL internet ?
-: Can put USB wifi router or adapter in Cisco router to connect wifi?
I search some router but didn't understand how they will connect to DSL without cable.
https://www.amazon.com/HooToo-Wireless-Performance-10400mAh-External/dp/B00RVIGY1I/
Please help me. Thanks very much
DSB
yes, I understand what you are tyring tio do; namely use the companies internet on your personal devices.
I'm not willing to help you do this. Where I work that is Instant termination.
Go get permission from your company and they can help you set it up securely.
Hi. I try to connect DSL internet to wifi by wireless router. I read can buy new wireless router then connect with DSL modem then can use wifi on mobile or other device.
But i don't know much information abt router which router can help then i can connect to wifi.
Looking for router without cable like power bank just put the plug an connect to DSL modem.
What's your advice?
Thanks
Hi,
Yes. I'm work there security guard. they keep the computer in my cabin for worker on/off duty and connect the internet with DSL modem. set up the connection same like showing in the photo.
http://static.tp-link.com/resources/UploadFiles/Images/0506d-1.png
DSL modem is from this company ( http://wwwen.zte.com.cn/pub/en/products/access/cpe/201111/t20111110_262348.html )
also put another router is Cisco 871. which is connected to DSL by LAN cable to Cisco router in WAN port then desktop to cisco LAN.
I can't use wifi on my mobile or ipad. Hope you understand what i need.
Thanks
Thanks very much.
