How to connect f&d 550x 2.1speakers to Samsung led tv
Hi ,
We bought f&d 550x 2.1 speakers and trying to connect to Samsung led tv. There is a cable with red and white pins on each side. We have connected one end to audio ports of tv and another end to input port of subwoofer but sound is not coming through thia way.
With a 2.1 speaker system the sub-woofer usually connects to the other two speakers, not to the TV.
Now, everything I've seen says that the 550x speakers are Bluetooth.
So the 550x speakers then connect to the TV via Bluetooth, not by wires.
If your TV has built-in Bluetooth, then read the TV manual where it explains how to connect Bluetooth devices.
If your TV doesn't have Bluetooth then you've bought the wrong speakers for the job - in that case you need a set of wired speakers, not Bluetooth ones.
That's all the information I have.
