I have gotten this motherboard and it came with no instruction manual on how to install the little connectors that say + and - on them. Where should they go?
@terry4536 I have used the manual and I was missing the speaker + and -, the message/power/sleep LED and the chassis intrusion header. Do I need those for it to work or will it work without?
They are for the power and drive activity LED on the front of the case. It also connects the power and reset buttons to the motherboard. So you do need to connect them.
