how to connect front panel connectors to the motherboard gigabyte ga-ep45-ds3l
duffykas
Commendable
Jun 25, 2016
8
Hello. Please help me to connect front panel connectors to the motherboard gigabyte ga-ep45-ds3l.
I try to read manual ant its not helping. Because it is very meaningless to me. Theres no written how to connect hdd led and others. In what direction I need to put them. There is hdd led power led m/b sw reset sw. Please help me. Thanks.
Maybe it will be best to unplug all the FP connections, and then just plug in the power switch pair. Test the system to see if it starts. Be sure you are looking at the FP header from the correct way. The pic in the manual is with the header like this:
The pin-out is also printed on the board in very tiny type right below the header.
I put them like shown in manual and now i cant turn my pc on. The power button just lights blue light but nothing happens when I try to turn it on. 🙁
Have you ever had this board in service before? Do you know if it is any good?
Yes. It worked until now. I accidentaly took out connectors ant after i put them back (with manual) it doesnt work anymore. Just blue light on my power button.
