How To
How To Connect Macbook Pro To Air Pods
MacBook Pro has some exceptional unique features including the OLED light, the multi-functional touch bar, the thunderbolt ports, and the personalization features. Many people preferred getting the MacBook Pro as it is much thinner and lightweight in comparison with the other MacBooks. AirPods is one of the renowned accessories introduced by Apple. With AirPods, you can listen to the audio wirelessly and is so compact to use. Here is how you connect the MacBook Pro to the AirPods.
Step 1
Open the AirPods case
Firstly, ‘Open the AirPods case’ as shown in the below image. You will find a small LED light which is usually green or sometimes red in color. It denotes that the AirPods case is in the right condition, completely charged.
Step 2
Press and hold the button at the back
Now, ‘Press and hold the small button’ at the back for some second until you find the blinking LED. This is a very important step to ensure that your AirPods is paired well with your MacBook Pro.
Step 3
‘Blinking White LED light is displayed’
Once the small back button is pressed and held for a few seconds, you will notice the ‘Blinking white LED light’ [/b] right at the center of the AirPods. It will be similar to the light marked in the below image.
Step 4
Click the ‘Bluetooth’ symbol
Now, on your MacBook Pro, ‘Click the Bluetooth’ symbol which is present in the title bar as shown in the below image. You will see a list of Bluetooth options available for your MacBook Pro.
Step 5
Click the ‘Open Bluetooth Preferences’ option
From the options of sending the file to the device, browse files on device, open Bluetooth Preferences, turning Bluetooth on, click the ‘Open Bluetooth Preferences’ option as shown below.
Step 6
Click the ‘pair’ option
In the ‘Bluetooth Preferences’ window, you will find the list of available devices. After a few seconds of searching nearby devices, you will find your AirPods getting listed. Here, click the ‘Pair’ option to pair the AirPods selected to your MacBook Pro
‘You can now connect the MacBook Pro to AirPods by following the above steps’
