Hello,
As the title says i have more case fans that i want to connect than i do motherboard fan headers i.e (SYSFAN)
Motherboard is: MSI X99S SLI Plus ATX LGA2011-3 Motherboard
http://uk.pcpartpicker.com/part/msi-motherboard-x99ssliplus
The motherboard has 2x CPUFANS (i am using 1 of them with my cpc fan) and 3x SYSFANS. i will be using all of them up with case fans but i still have 2-3 more (3pin)fans i want to connect?
How will i be able to connect them? do i need an adapter? Ive heard using a splitter is not recommened? Also a fan controller ruins the look of the case in my opinion but still might consider.
I have a square 6 pin PERIF cable that connects to the power supply with 4 female molex connectors attached like a chain .
Should i buy some male molex to 3pin connectors and then connect to my 3pin fans? is that right?
Sorry im new to building pc's
Hope someone can help, thank you!
