Question How to connect my HDTV to this stereo system?
Mar 26, 2019
7
Got this old stereo system(I think it's called?) and thought I'd put it to use. But I don't know how to connect it to my TV. Here are pics that show what's behind both.
How would I go about connecting the two?
What are those RCA jacks on the stereo?
If they are inputs you could come out of the headphone jack on the TV with this...and go to those inputs (if that's what they are).
https://www.amazon.com/AmazonBasics...ocphy=9005448&hvtargid=pla-303037967706&psc=1
Yeah! That's what I was thinking! Those RCA jacks on the stereo say "AUX IN". I tried some original Xbox cables(the 2 audio ones) in there and they fit perfectly.
One more question, just in case. Does the color of the cables matter? I found some locally too, but instead of red and white, some of them are yellow and white, black and red, etc... But they all seem to be the same thing. Look the same and say "AUX 3.5mm to RCA".
Actually, the color might matter. If the cable you have with white/yellow has 3.5mm audio at the other end, it's quite possible this cable came from a digital / video camera, and it might not be compatible. And you definitely need a cable like the one referred above.
