How to connect PC+ Creative Sound card + Sony DAV-DZ370 5.1 Home theater
82
Hi,
1. I have a T7500 Workstation with Creative Sound Blaster X-Fi Xtreme Audio Sound Card PCIe SB1040.
2. I have also Sony DAV-DZ370 5.1 Home theater.
How can I connect my Workstation with Sony home theater to get 5.1 surround sound (in game play and movie ?
Any assistance or guidance that would be appreciate.
Waiting for your valuable comment.
Thanks.
Hi,
Thanks for your reply. I order it instantly.
But how can I connect it. Could you please comment with detail ?
Thanks
Thanks for your quick response.
Will it be helpful ?
Creative Labs Sound Blaster X-Fi Titanium Sound Card PCI-E SB0880 F333J
http://www.ebay.com/itm/201814752838?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks
Your Creative card should have an optical output jack. It is the grey one labeled Optical Out. Your stereo should have an optical input jack. You connect the output of the card to the input of the stereo. Then you just change sources on the stereo to the optical jack.
Sometimes the computer does not automatically detect the new audio device. If you have problems post again for solutions.
Hi,
Please do have a look at back image of Sony DAV-DZ370 5.1 Home theater.
home
Will it be helpful for me ?
Thanks.
That picture requires I have a dropbox account. According to the specs it has an optical input. That is a standardized connector. The cable type I showed you should work fine.
Thanks, Let me buy and test it. I will keep posted if it works for me...
Hi,
Awesome, I changed it in receiver's menu...and It is working..
Thanks all guys, You people did a great job.
Thanks.
