How to connect Playstation2 to my vga monitor
sanzinlove
4
Hi i have an PS2 which i want to use it with my vga monitor,but i dont know how to connect it.I also have an XFX geforce 6600 graphic card in my pc with an DVI-Out,can i connect through it or else is there any procedure could you please tell me..
Component/Composite -> VGA Converter:
Simply plug the relevent video plugs into the converter, then plug the VGA end into you're moniter.
VGA Cable:
Buy a third party cable that instead of component/composite, uses VGA is its output type. (Such cables still come with stereo RCA plugs for sound)
