H Hamim Rozak Honorable Aug 21, 2013 194 0 10,690 Jun 29, 2014 #1 i got a desktop but it cannot connet to wifi. how to make wifi available with a router?
Solution I I i7Baby Jun 29, 2014 Asus N15 - http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=asus+n15&N=-1&isNodeId=1
dandn0ten Reputable Feb 19, 2014 754 0 5,360 Jun 29, 2014 #2 do you have wireless adapter? Upvote 0 Downvote
woworwow Honorable Jan 18, 2014 830 0 11,160 Jun 29, 2014 #3 Do you have a wi-fi card or your motherboard comes with a wifi antena? Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jun 29, 2014 #4 If your pc is close enough to the router you an just use an ethernet cable. If not, and you don't have one built into your pc, then you need to get a wifi card eg Asus N15. Upvote 0 Downvote
H Hamim Rozak Honorable Aug 21, 2013 194 0 10,690 Jun 29, 2014 #5 dandn0ten : do you have wireless adapter? well i don not have that but i have a router Upvote 0 Downvote
woworwow Honorable Jan 18, 2014 830 0 11,160 Jun 29, 2014 #6 You need a wi-fi adapter to connect to wi-fi in a pc Upvote 0 Downvote
H Hamim Rozak Honorable Aug 21, 2013 194 0 10,690 Jun 29, 2014 #7 woworwow : You need a wi-fi adapter to connect to wi-fi in a pc could you give me the link where i can find a wifi adapter Upvote 0 Downvote
woworwow Honorable Jan 18, 2014 830 0 11,160 Jun 29, 2014 #8 You can google it or visit your local computer store. What country do you live in? Upvote 0 Downvote
H Hamim Rozak Honorable Aug 21, 2013 194 0 10,690 Jun 29, 2014 #9 woworwow : You can google it or visit your local computer store. What country do you live in? malaysia Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jun 29, 2014 Solution #10 Asus N15 - http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=asus+n15&N=-1&isNodeId=1 Upvote 0 Downvote Solution
