Question How to connect two monitor from motherboard
Jul 4, 2020
6
I want to use two monitor, my motherboard have a vga ports and dvi-d port. Can i connect two monitor from it ? or not
Jul 4, 2020
6
That adapter will not work. It's DVI-I to VGA adapter. It will not fit into DVI-D output of your motherboard.
If it fits, then it's fake.
You'll need active DVI-D to VGA adapter. Like here:
Yes. That's the same wrong adapter.
It Will not work. Ever. Fake product.
so, I need a graphic card for that to work
if you have any other suggestion other than that please tell me.
Jul 4, 2020
6
Will this work :-
Will this work :-
Not sure. That amazon link gets translated to UK site for me.
If it looks like picture in post #6, then it will work.
To convert DVI-D digital signal to analog VGA, active signal conversion is necessary. The cheap passive adapter you were showing me before will not work for this.
Active DVI-D to VGA adapter is necessary. Like one in post #6.
