Question How to connect water cooling on Gigabyte B650 AORUS ELITE AX
Nesule
4
Hi,
I bought Gigabyte B650 AORUS ELITE AX and Endorfy Navis F360 water cooler and I'm not sure where to plug the fan and pump connectors. Normally I'd plug the pump to CPU_OPT and the fan to CPU_FAN (top-right part of the motherboard), but after reading the manual I'm confused, because it speaks of:
  • SYS_FAN4_PUMP (System Fan/Water Cooling Pump Header) - located in a different part of the mobo, to the right of RAM slots
  • CPU_OPT (Water Cooling CPU Fan Header) - so.. I connect the fan cable to CPU_OPT???
motherboard manual in PDF
water cooling manual in PDF
png with the problem description
