P ponnada.raji Prominent Oct 3, 2017 2 0 510 Oct 3, 2017 #1 Can someone help me , is there anyway to connect wired headset to LG Tvs
Solution Ralston18 Oct 3, 2017 Google "digital audio out to headphone adapter". Limit the search criteria to the last year or so. For example the following link: https://www.digitaltrends.com/home-theater/how-to-connect-headphones-tv/ Note the paragraph beginning "Newer TVs".
Ralston18 Titan Moderator Oct 11, 2014 39,447 4,396 146,290 Oct 3, 2017 #2 What model LG TV? Do you have the TV's User Guide/Manual? Most TV's have a 3.5 mm (1/8th inch) headphone/headset jack. The jack could be located on the back or up under the lower screen edge. Or on a side perhaps. And you may need to configure the TV to use that jack but generally just plugging in a headset will automatically send audio to the headset. My LG TV has an audio port on the left side edge. Look for a small icon that looks like a headset. Upvote 0 Downvote
P ponnada.raji Prominent Oct 3, 2017 2 0 510 Oct 3, 2017 #3 Tv models - WebOS - UH6030 or LF595B It does not have any audio port. But i has optical digital Audio out. Upvote 0 Downvote
Ralston18 Titan Moderator Oct 11, 2014 39,447 4,396 146,290 Oct 3, 2017 Solution #4 Google "digital audio out to headphone adapter". Limit the search criteria to the last year or so. For example the following link: https://www.digitaltrends.com/home-theater/how-to-connect-headphones-tv/ Note the paragraph beginning "Newer TVs". Upvote 0 Downvote Solution
