[SOLVED] How to control case rgb fans from mystic light
Aug 25, 2019
I have a b450 tomahawk and the case thermaltake v200. I am able to control my motherboard rgb with mystic light but cant figure out how to do with my case fans. I have turned them off like it says but cannot control them still
You need to connect the fans to the RGB header on the motherboard, mate. There appears to be one header at the top right of the motherboard, and one at the bottom left, both are marked JRGB. You may, however, require a 12V RGB extension cable, as well as a 3-way adapter, depending on how those three RGB front fans are connected in your case.
