How to control CPU fan speed
TechnoViking18
26
Hi , i use gigabyte z97x gamig3 MOBO and i5 4690k CPU , i can OC my CPU and monitor its temp using gigabyte's easytune app but i can't control the fan speed. Does gigabyte have an app for that or do i have to download smth else i checked gigabyte's website but couldnt find smth useful.
I don't have experience with your motherboard but controlling CPU fan by user is not a feature i have seen in any motherboards or even in any forums. Since the CPU fan is a priority fan , you cannot control it on your will , the CPU will control it . At most you can tweak the voltage feed methods or active/passive cooling or always on in the BIOS settings.
There is a utility called speedfan but i doubt it will serve your purpose.
