This post here will help you but in a nutshell you should be able to dependant on the motherboard as it should also have a DC control method. What model and make of motherboard do you have?
https://forums.tomshardware.com/threads/is-there-a-way-to-control-3-pin-fans.2905718/
I have asrrock h310m-hdv/m.2 moboThis post here will help you but in a nutshell you should be able to dependant on the motherboard as it should also have a DC control method. What model and make of motherboard do you have?
i alrdy conncterOk I have had a look at your motherboard manual and you have 2 fan ports. 1 called CPU_FAN1 and one called CHA_FAN1/WP.
They both seem to be DC and PWM so you should have no problems controlling your 3 pin fans.
This motherboard provides a 4-Pin CPU fan (Quiet Fan) connector. If you plan to connect a 3-Pin CPU fan, please connect it to Pin 1-3.
If you go to section 4.8 of the manual - 4.8 'Hardware Health Event Monitoring Screen', you will see how to control your fans through the BIOS via:
Fan Tuning
Fan-Tastic Tuning
Thank you manOk I have had a look at your motherboard manual and you have 2 fan ports. 1 called CPU_FAN1 and one called CHA_FAN1/WP.
Fan Tuning
Fan-Tastic Tuning
