Hi, I got a new CPU Cooler, Cooler Master Seidon 120V and it's pretty good idle temps in 30s and load temps in 50s with spikes to 60s. However upon using HWMonitor, I found out that it says my fan speed was 2400RPM for FANIO0 (pump is in CPU_FAN header, Fan on radiator is in SYS_FAN1) so I was confused. upon downloading Gigabyte System Information Viewer (my board is a z87-hd3) I found that I can control the speed of the rear fan (the fan on the radiator) and that it should be following the graph in Smart Fan Advanced but instead it lets me choose the rpm myself and I can select from 0 to 2400rpm (very loud). So my questions are how do I get it to auto adjust the RPMs based on workload? I have the curve set but it's not following it :/. Also is my pump suppost to be set to 2400rpm does that mean my mobo is giving it max power? It seems to think that it should be that all the time.
If you need any more info, ask.
Thanks!
Thanks!
