I know that Noctua NH-D14 comes with two fans that have only 3 pins, whereas the asus p8z77-v motherboard cpu fan can only be controller using PWM. so I guess the Noctua fan will always run 100% in this case.
Is there any method that I can use to avoid having the cpu fan running at full speed all the time? (without replacing the Noctua fans ofcourse)
Thanks.
Thanks.
